PRHeads
- 6:06 PM
- Aug 31, 2018
- So. Burlington Vt
Ootb Stealths usually flow in the upper 250’s.
With fairly basic work they will flow in the 280’s.
On my bench, the CNC’d ones are about 312-315.
How much benefit you’ll get from each stage of porting with be dependent on how hot or mild the overall combo is, and how much the heads and induction are holding it back.
With the heads mildly reworked, with say 9.7:1 and a moderately sized cam, 6bbl, 1-7/8” headers...... it’s an easy 600-620-ish tq/540-550-ish hp.
That’s using a SFT that would likely be marginal for power brakes.
(You could mellow the cam out a bit for the brakes and not lose much power)
I’ve done several sets of various heads for those combos, but have only dynoed one myself.
That one had stage 1 RPM heads, and the intake had some port work done to it, along with it being around 11:1.
The SFT cam would likely have not been power brake friendly, and it was run with 2” headers.
That one made 645tq/590hp.
