65 dodge 65
Information on the 518 max wedge heads
hi thanks for chatting.i have two setts of virgin 518 heads one set is after market and the other set is original these are bare heads
Thanks I have a stage 2 intake gross ram will it work on the reproduction heads without any.issues thanks jackIf I'm hearing this correctly, you have original 64 MW heads, and another set of mopar reproduction? Sell the originals for money. Yes headers work. Indy cylinder heads make an intake that will fit. You would have to resolve a valley pan issue.
Or use a factory or aftermarket crossram manifold.
I'm thinking run the aftermarket heads on the street with heads.will a stage.two intake work with the.aftermarket heads I know the ports are different so do I do any thing to the heads or run it as is.sell the other heads thanks for your time.not doing any racing myself.
Thanks I will right now.now having them cleaned.up an checked for cracks with will be a couple weeks from.yesterdsy do you of any that migjt.be.interested in a set thanks jackPlease post some photo's of the heads from all sides, Thank you
Hi thanks for your reply.im having them cleaned up and.chevked I plan on selling the.original 518 bare heads though if they check out wha would be a fair.price I'm not trying to get the.highest bid.just some that would actually use them for a a super sto kernel or something on that order. Thanks jack that's my nameThe stage 2 intake will work without issues. A&A trans makes/sells an aftermarket crossram too, if you should need one. I havta agree with RemCharger on this.... you could likely get a real good buck for that original set if you chose to go that route. I think racers are hunting the aftermarket sets too actually, since they are now also very tough to find. Best of luck whichever way you go.
What are the part #s on the ( aftermarket) heads. Are they max wedge size port?Thanks I will right now.now having them cleaned.up an checked for cracks with will be a couple weeks from.yesterdsy do you of any that migjt.be.interested in a set thanks jack
