FOR SALE 540 World Products short block pump gas
Mojoluv
11:20 PM
Louisville, Ky
I have a 540 short block for sale. This is a World Products iron block made for Mopar Performance. It is 4.500 bore. The block was ran prior to this build and has been repaired by Ray Barton. Standard bore. Brand new Molnar 4.250 8-bolt knife edged crank, new Molnar H-beam connecting rods 6.76, and new Diamond dish forged pistons. Custom grind Bullet roller cam for this combo. Cam is around .675 lift. I also have a used Milodon single external pan that comes with this. Clevite fully grooved mains. Hellfire rings set for nitrous. Engine will be 11.3:1 with any 74cc head. Must use .070 Cometic as piston is out .033. $6500 in Louisville, KY. I can crate and ship. Have several freight companies close by.
IMG_1336_resized.jpg IMG_1530_resized.jpg IMG_2060_resized.jpg IMG_2355_resized.jpg IMG_4490_resized.jpg IMG_4714_resized.jpg IMG_6207_resized.jpg IMG_7051_resized_1.jpg
Was the block ever run after the repair, to check for leaks? I'm assuming it kicked a rod out the side from the pictures.
No has not been ran but has been pressure and sonic tested. Breaks did not get into water.
