D575
- 4:41 AM
- Feb 22, 2012
- High Desert, Northern Nevada.
I'm sure most of you have already figured this out, I was having problems with the choke staying on way too long, it would foul plugs and just about gas anyone near the car. there doesn't seem to be any options for the six pack as far as manual or electric choke. I removed the choke rod and fired it up. I came to the conclusion that I really don't need a choke here in calif. so after a little experimentation I ended up making a new choke rod only 3/8" shorter. I made it out of welding rod I had laying around the house. I made the groove for the circlip with a tubing cutter.
now it fires up without blubbering and having to hold the throttle , it still uses the fast idle cam .
another issue I was having was run on. not all the time It depended on the quality of gas I was running. I bought a Holley universal idle solenoid and made a bracket.
I can't believe the difference .
