Well some updates. In addition to the trans it had some strange oil pressure readings. Very high cold. On the low side when hot. Good thing the trans didn't work limiting us to one pass. Guy that built the engine came and looked at it for the oil pressure issues. He inadvertently crossed the remote oil filter lines. No oil going thru the filter. The only flow was from the additional -6 line plumbed as extra measure to the rear of the oil galley. This turned out to be unfiltered due to the routing. Pulled the pan. Bearings will need replacement. Engine is coming out today for a total teardown and inspection. The trans was tested for pressure 50psi in reverse. None in forward. Pretty sue there a valve body issue. We'll address that as well.
Doug
Doug
