63-64 Hood?
evilmopar
1:29 PM
Jonkoping, Sweden
Does anyone know if the hood on a 64 Fury is the same as on the 63? They look the same but will a 63 hood fit a 64 car?
Does anyone know if the hood on a 64 Fury is the same as on the 63? They look the same but will a 63 hood fit a 64 car?[/QUOTE;
Except for the trim they are the same. 63/65 deck lids are the same. 64 deck lid is different. Except for the latch location (must be welded and swapped) 63 doors will interchange with 64/65
Doug
63 doors will somewhat interchange with the 64-65 cars. They swing , they latch, but they have this big gap at the upper front because the 63 windshields are leaning back an inch or two. Been there done that. I make and sell doors and that question is asked once in a while. 64-65 uppers will not let the doors close on a 63 body. I also make the hoods for the 63-64 Plymouth and they are pin on and are the same mold. Steel hoods are different in the latch area.
I guess I should have stated H/T with a vent window/window track swap. Or use the existing door frame.
Doug
