64-65 arm rest pads
moparlouie
8:51 AM
Moosup
Feedback: 6 / 1 / 0
Arm rest pads and mounts, mounts are for wagon or 4 door, pad is the same for all. ! Rear mounts are the same for all too! $50 for all, or $40 for just
the pads? Drivers is cracked.
will these fit a 64 440 2 door hard top? mine are red on bottom also, i assume i can paint them.
Yes they will fit, some models had the longer front bases with cutouts for the door handle, but these will fit, if you have the holes in the right spot for them in the door panel itself to pass through? Do you have the correct screws to attach them? I think all the plastic is good. Like I said, only the drivers has some cracks. Let me know, and there yours? Thanks Lou
