Hi guys, I am having an issue with my engine missing around 5k rpm. I removed the petronix distributor and installed an MSD 6AL box with a new msd distributor, and it still misses with a hard launch. Any help would be appreciated. Thanks
30° total or 30° initial?Thanks Frank. The MSD feed is on the ignition switch. I talked to a mechanic this afternoon and he thinks it is running out of advance timing. Said to give it 2 or 4 degrees advance. The engine is fresh and it is not stock. Full advance is set at 30. sounds like a lot but will try it. I trust him. He is an mechanic from way back. peace Frank, and stay safe.
Bob
That is 30 deg total30° total or 30° initial?
My issue was similar. Drove me crazy. Finally tried a few thousandths more plug gap and it worked wonders. Had already changed wires and plugs. Dave
You are 6 or 7° short. Some engines like 35°, some like more.That is 30 deg total
THIS!!You are 6 or 7° short. Some engines like 35°, some like more.
Tks. Dave for the input. Never heard of that. Will put on to do list.
How much total advance are you set at ?
36* Locked in. Us an MSD retard for easier starting.
