O'l geezer
Tks 65 x 3
Doug, the miss was at 5K. I advanced a couple of deg. and the miss went to 5500. going to try a couple more deg. hopefully later today. will post results.Not enough timing will slow it some. But it will not cause a miss. When does it miss? Only a the hit?
Doug
Timing should not affect miss. Weve run stuff as low as 21 total.Doug, the miss was at 5K. I advanced a couple of deg. and the miss went to 5500. going to try a couple more deg. hopefully later today. will post results.
Hmm, I need to look at something else..Timing should not affect miss. Weve run stuff as low as 21 total.
Doug
Well I have been checking things and doing research on what could be my problem.Hmm, I need to look at something else..
Hi 66, the roller cam was the one I had trouble with. With the rebuild I went to a hyd. flat tapitt cam. the rockers are new steel type. BobWas the roller cam setup new with the rebuild? Did the rollers fail? Which rockers? Retainer to guide clearance? If you have a solid roller cam motor seems like you should consider a big electric fuel pump with a big fuel line. Just my opinion.
FWIW, I suspected that the springs on the stock 452 heads on my 440 6bbl were weak when I first got my Roadrunner. I also had problems with a lifter or 2 collapsing when I missed a shift (shifter was a pile of mismatched crap)5500-ish is often where hyd lifters start giving up...... especially if it’s a faster rate type cam.
Yes, and my best friend did great with that setup on his 70 Roadrunner 383 4 speed. The electronic fuel pump had a pressure setting on it, and he kept the mechanical pump on it too.Can I install a small electric fuel pump at the tank and leave the mechanical pump still hooked up to try and see if the problem stays ?
I'm not familiar with the details of that pump, but be sure to have some way to control the fuel pressure.bioguy thanks for the comment. am going to try electric fuel pump, a Holly Red one.
