Trying to determine and locate the brake parts needed to get my 64 Fury going, er, stopping. The car is in VGC, sat a while in storage, but nothing is rotted. Single master cylinder is empty, but no rust inside. I want to replace parts, not upgrade anything at this point, except for a 65 dual mc.
It has power brakes, 4 wheel drum.
My front drums' inside diameter is 10", and the pads are 2.5" wide.
Front wheel cylinder has part #2266368R stamped into it.
According to this, the rear drums and studs can be replaced:
http://hotrodsandhemis.com/TaperedAxleBrakes.html
Studs: BK 641-1128
Brake drum: ND 4401129
Also, according to another member, Dorman studs work as well on the rear: 610-090
https://www.forbbodiesonly.com/mopa...ds-for-62-10-rear-drums.79344/#post-910140206
Will the the drums and studs listed above fit the front as well and allow the conversion?
I'm having a hard time locating parts, even the ones listed above.
When I look up brake parts for a 64 no luck, look up a 65 and they are available.
Cardone booster 54-73456 is available for a 65, will this fit a 64?
What wheel cylinders, brake shoes, and hoses fit?
Between NAPA and Summit, it appears I can get what I need, however I might have to mix and match between 64 and 65, and guess unfortunately.
Just wondering if anyone has gone thru this before.
