Thank you for all the replies. I will get some pictures later today. I have the engine, bell housing and clutch all assembled on the floor. Need to test fit the starter and make sure it engages. I really appreciate the photos of the original cars. I did not realize they cut the floor out of a standard, automatic hump. I thought there was a different floorboard used from the factory. That is crude! I will do my best to cut it out in one piece HEMI-ITIS! I used a kit from RAM that was suggested by Jamie at Passon. It's supposed to be good to 550 HP. This will only make around 450 at the flywheel. It's a Borg and Beck style. When I installed the tool to line up the clutch and pressure plate, it fit perfectly. A buddy of mine advised me to try it on his output shaft. It fit the tool, but did not fit the factory input shaft. I then tried it on my transmission, and it would not go. Jamie replaced it with an equivalent one he had on his shelf from McLeod. That one fit perfectly. If I had not taken this step, it would have been a major problem to replace inside the car.
I too love push-buttons, but three, black, automatic B-bodies is a bit monotonous! I'm long overdue for a 4-speed, and this is the only one of the three that I would not hesitate to cut! Call it a mid-life crisis! At least it's not a yellow Corvette and a wig!!
Centerline, the photo of the chassis on it's side is a big help. I haven't crawled under the car since deciding to go this way. I did not realize the cross member was so close to my cut line.
64 Post, I'm doing it your way. Thank you!
