65 Belvedere Steering Column
Bob maio
1:29 PM
Hebron, CT
I am looking for a 1965 Belvedere steering column with the 3 speed standard column shifter. Grandson is trying to restore his Belvedere back to factory which was a 3 speed on the column. Also need the linkage from the column to the tranny. Any help would be appreciated.
I “think” the column is the same. You just need a linkage and the correct steering column “collar”. What column is in there now?
I definitely have the linkage arms from the column to tranny. I need to look if I kept the bits that go on the end of the column where you attach the linkage. I also have a manual steering shaft. I re-used the outer column tube in my build though. Give me a day or so to look for what I have.
