I'm fitting a plastic replicate 426 hemi in my 65 Coronet. But something isn't right.
a) The engine is offset 2" toward the passenger side. Isn't it supposed to be 1-1/2" ???
b) The engine sits too high. The crack CL to k-member is 5-3/4". Isn't it supposed to be 5-1/4" ???
c) There is only a 1/4" gap between the block and passenger shock tower. Seems to small.
I'm using reproduction mounts and isolators. The k-member was modified by Mega Parts.
I suspect my Plastic replicate block may not be correct.
1) What is the distance between the machined mounting pads an a steel block???????
2) Is the crank centerline half that distance?
3) What is the width of a steel block, with no heads??
Don
Don
