66 Coronet 440 4dr 318 poly $1000 in MI
440clark
New Member
10:53 PM
Commerce Twp.
This car sat for about the last 10 years in a garage. The guy I got it from was going to fix the body and paint it but lost interest. It needs a carb rebuild to even drive. I'm sure once it starts being driven it'll need the usual, brakes. master cyl. waterpump,alt., fuel pump. That's how the game usually goes. The body has some rust here and there but nothing too scary. There is a hole on the pass side floorboard that looks to be an easy patch. It comes with two patch panels for the front doors. Like I said 318 polyspherical with a 727 torqueflite and 8 3/4 rear end, not sure of the gear or if it has a locker. It's a 45 year old car it aint mint but certainly not beyond fixing. 4 bf goodrich 14 inch tires that were probably put on new before it was put away. gas tank is out of it right now, I rigged a small eng. tank to start it on while I clean out the old tank. Other than that if you are interested come out and take a look. $1000 firm.
I have the other 2 original hubcaps I'll let go real cheap if you're interested.
That car is in pretty good shape, really.
