WTB 67-69 two groove crank pulley
miller
8:57 PM
Tom Bean,Texas
Feedback: 1 / 0 / 0
Need a stock two groove crank pulley, for a steel crank, with the one offset hole. Non AC, of course.
Also looking for a one groove water pump pulley, that aligns with it.
I might have these pullies I will check and send photos so you can check if they are what you need.
Thanks for responding, eespeed...tried to PM, but your inbox is too full!
I'm working on a 69 model 440, steel crank, non a/c.
So the pulleys I'm looking for are the two groove crank pulley, with the one offset hole. Believe 69 and earlier would be the right one. The water pump pulley is the deep one groove. That pump pulley is the one that lines up with one of the crank pulley grooves.
All I have planned on the motor is water pump, PS, and alt.
Can't use the pulleys off the engine, since they are not the normal set for a non a/c car. I could buy re-pops, but prefer original pulleys.
Thanks for looking!
