BatMiro
Cheers to all members,
I saved a '67 Coronet roller off the crushers, It had had a slant plus three on the tree, long time since gone.
As I have a running mid 80s 318+ 727 out of a truck (with a car oil pan on it), I am aiming of planting it into it.
I can't benefit from sourcing a correct 318 B- body K- member, the slant one ( quite awkward looking) has to be modified to take the 318 and here comes the question- which type of mopar mounts is the best way to go? I have got the truck- 318 brackets I can use or modify, or should better go for the big block type of a mount with a single bolt and welded nut on it?
As an addition, I also have an E- body small block V8 K- member I have no use for, but would it fit the B- body platform? I have read some confusing statements of different between E and B- bodies steering box flange angle. Any thoughts?
Thanks to all the knowledgeable peers.
Best of wishes from Europe.
