Yes. I bought a new tank from Rock Auto and cut and welded in the Tanks adaptor. Been in 3-4 years now, used a 98 Ram 360 with factory EFI and AOD. Worked out well-have had no issues at all.Has anyone tried putting one of the in tank fuel set-ups from Tank's Inc of phantom into a 67' B-body tank?
No pics-sorry! If I recall correctly-the Tanks home page shows the pieces and a short how to. I'm not sure who_-Holley?-someone has a setup that lets you use a regular mechanical pump to bring fuel to the engine bay-where it dumps into a small sump that has an electric pump to get EFI pressure. Looks like that might be a simple way to make things work w/oDo you have any pics of the tank build?
Looking at the FiTech Fuel command but would rather have an in tank set-up
No pics unfortunately. Have you looked at the Aeromotive "Stealth" EFI pump yet? You still need an access hole-but it requires no welding. Looks like a simpler way to mount the pump in the tank.Do you have any pics of the tank build?
Can you tell me if this fuel tank is for EFI?? has a built in fuel pump.. ThanksI'm waiting to see who builds an EFI tank for the 67's first. I'm gonna need one, also.
