MOPOWER871
Gentlemen, the dimmer switch on my 67 GTX has a mind of its own from the day I purchased the car. I pulled the headlight switch for inspection and the rheostat looked a little oxidized so I cleaned it up reinstalled it, same problem. harness contacts looks perfect .
I changed out the headlight switch with a standard motor new piece, same problem. Its feels like there's a sweet spot and if you turn the dimmer the dash lights flicker and go out along with everything on that circuit (tach and console lighting) and wont come back on unless I pull on and off the headlight switch wiggling the dash knob until it finds that sweet spot.
It almost seams like a physical problem.like the pointer on the rheostat loses contact. so for shits and giggles I bent the pointer to apply more pressure and it seams like it made some improvement but still the same problem.
I purchased a NOS switch, installed it and same thing. all the wiring is original and under the dash and looks time capsule fresh..fuses have been replaces and fuse box looks clean.
Any help pointing me in the right direction would be appreciated. Thanks in advance.
