TX67RT
I have a '67 R/T with a 440 Magnum and 727. I'm going to start driving the car this summer, and may freshen up the transmission soon because the car has it's original, unrestored driveline.
My question: Is the transmission behind the 440, the exact same set up as was put behind the Hemi? I seem to remember that the Hemi set-up used an extra steel and fiber in the clutch pack, where the 440 set-up had an extra thick rear steel to take up the space of one less clutch disk set.
It's been forever since I worked on a TorqueFlite, and want to know if they're different, can mine be modified to add the extra clutch disk set. Also, were there any other differences? I'd like to take advantage of any improvements I can make to the transmission if/when I pull it out for freshening.
Thanks!
JD
Thanks!
JD
