SOLD 68-69 and possibly 70 B Body AC vents
erikcroissant
1:54 AM
California
Feedback: +12 / =0 / -0
68-69 B Body AC vent/duct parts. I believe these are all the same as the 1970 pieces minus the center vent frame, but I’m not sure.
Center Vent/Ducting are in excellent condition. The vent and metal frame are like new, one side of the vent has a tiny bit of resistance moving up and down, that’s it. Everything is aligned correctly, vents open/close/angle perfectly.
The duct that attaches to the back of the vent is in pretty good shape, even the foam seal that attaches to the AC box is in good condition. Don’t have any mounting screws. $300 obo shipped from California for all three pieces.
As for the side AC vents, they are in OK shape, missing some hardware and the plenums are warped a bit, but not too bad. The vents themselves move freely and are aligned correctly. The ducting is in great shape, perfect for a driver car. No mounting screws for these vents either. $200 obo shipped for both side vents and 3 duct pieces.
Would prefer to sell everything together and will do a discount for that. These would be perfect to add/fix AC on a driver car, or even a show car with a little work on the corner vents.
Can also add addition photos of specific pieces if needed, please just ask. Thanks
I am interested in your center AC vent. How does the center vent mount to the center bezel and to the dash? I have a non AC car that I'm trying to convert and can't find any info on how everything mounts up.
I tried to dm you, but your inbox is full
Just cleared my conversations sorry. However, all of the items are pending sale, I will reach out and let you know if the sale doesn’t go through for whatever reason.
Unfortunately the non-AC and AC metal dash frames (the entire large piece) are different. The AC version has holes cut out in the center and corners for the three vents. It also has a different lower dash pad around the switches/ignition/ashtray and center vent. There may be other differences as well.
I believe you can cut out the holes yourself but may be tough. You may want to consider vintage air, they make kits for non-AC cars that add new vents under the dash, no cutting or new components required. Not cheap but likely much easier.
I had purchased these to convert my non-AC car to AC, however I got too cheap/lazy to try and make it all work so I just skipped it.
The center vent and bezel are screwed onto the dash frame right above the ashtray, they fit into the AC specific lower dash pad and line up with the switch panel.
I have been piecing everything together too. I have the side vents, the lower dash pad and the outer ring for the center vent. I have a center vent, but it isn't in very good condition. I will be using a vintage air setup, which has all the adapters to the original ac vents. I want the factory look ac, I don't like the look of the vents hanging off the bottom of the dash. Side vents are already installed. Not too difficult, just a little time consuming. I just need the center vent.
Gotcha, if the sale falls through I will reach out.
