mopar 3 B
- 10:22 PM
- Aug 25, 2014
- Kingsville, MO
Floor heat is controlled by two small doors on the bottom of the unit that are manually opened and closed. Small wheels stamped floor heat.
My manual does not show them. They are just above the front of the console.
From what I have found they will not heat the passenger compartment on their own.
So in other words, when you put it on heat, it should still blow out the dash vents? If so, then I guess I'm good.
Last question;
Is this the correct orientation as viewed on the drawing with #1 being the bottom left on the row of three & #7 being on the top left?
The heater should flow just enough to keep the condenser defrosted. Is your h valve hooked up? Not sure what you have it will be actuated by cable or vacuum.I would really like to know how yours work when done. Today I believe I understand the whys and hows of this system works. I had my core redone by Glenray and he can't get the correct thickness core anymore so it is thicker (more capacity). Now when I have the AC going and I try to blend in some warm air it is like I shut the AC off. The heater core "h" valve is in and functional. I believe its job is to basically shut off half the heater core when the AC is on for this reason so the heater does not over power the condenser when trying to blend in a little warmer air. I think Bob's cores are just too much core to make the AC/Heater system work correctly anymore. I have been thinking about putting a restrictor in choke off the flow to the heater core to try to compensate but I have not got to that yet.
If I am corret the Cornet used the same dash and heater box as the Charger.Hi Richard, I had a tricky question about figure 1 (attachment 497108) vacuum line routing that I'm also working through on my 68' Coronet. Vacuum lines 3,4 and 7 are white/black, while lines 1,2 and 5 are red/black. Line 6 is the primary vacuum line connected to manifold vacuum which I'll state here in case it helps anyone. It's my understanding that the "red lines go to the rod side" of the actuator as the rule of thumb and that the white/black lines go to the "pot" side or the top of the actuators. It's also my understanding that the white lines open the actuators, the red lines close the actuators. My issue is with figure 1 which you kindly uploaded. In the diagram, just using the fresh air door actuator as an example (lines 1 and 3), if I follow the "red to rod side rule" (not the diagram, but the rule), the red line #1 would go to the rod side and line # 3, the white line would go to the pot side (top). But if I follow the diagram, it would be reversed because the diagram, the way I see it, is showing the red line 1 going to the top/pot side and the white line going under to the rod side. Do you see that?
I have never depended on hose color whole placeing lines. Actually never gave it much thought as the ports are numbered on the factory diagrams and have always either pressure or vacuum tested the lines one at a time for proper placement.
See post 6 figure 46. It labels the function of each port.
But your observation is interesting and will look into it.
Thanks Mopar3B. That would make sense to me so it's nice to get the confirmation.Compressor or clutch missing from the system has no affect on door functions. Just do not expect cold air in ac mode.
Amazing thread, thanks tons! Everything I can see in all those awesome photos confirms the "red to rod side" theory supported in the video and "white to 'pot'/top side". The white is opening the system and the red is closing the system if I'm understanding what I've discovered.See if my thread helps you at all here:
http://www.forbbodiesonly.com/mopar...net-500-project.114333/page-22#post-910578933
Thanks for the link. Gradually putting the factory a/c back in my gtx and its good to have all these links. I was a bit confused with the colour hoses as well. Didn’t seem to match up with my diagram.Also, incase anyone chases down this link months or years from now, here's a good point for available reference materials http://www.mymopar.com/index.php?pid=446
Monroegtx, I believe I owe you a huge thanks! I ended up looking through your photos in your "garage". I was saying previously that all my switches at the back of the a/c heat control panel are wired correctly. I had been saying that I believe that all my vacuum lines are correctly connected to the actuators for the A/C heat doors. But I had been saying that the buttons just don't do what they are supposed to do. I took a long hard look back at the wiring diagram in my book AND at the pictures of your heating and a/c controls which you posted. I couldn't figure out how you were ending up with the blue wire for A/C on top until I stared and stared and stared at your photo and then looked at mine. Then the epiphany hit me. The previous owner had installed the heater a/c vacuum switch upside down! So all the buttons were not aligning with the correct valve actions. It's not even 6:30am here in California so I can't start her up quite yet but I flipped that heater a/c switch over! I'll keep you all posted. Thanks tons. Picture 1 correct from MonroeGTX, picture 2 NOT correct (my set up how it was), picture 3 corrected to match picture 1.Thanks for the link. Gradually putting the factory a/c back in my gtx and its good to have all these links. I was a bit confused with the colour hoses as well. Didn’t seem to match up with my diagram.
