1337du0
Recently picked up a 68 Belvedere with a 318 and it runs great except one thing, every time I hit 25 - 30 mph in D it kicks down into passing gear. I have tried adjusting the kickdown linkage using the open throttle method and there was no real change. After I made the adjustment, it did shift into third but only at 50 mph and with the throttle wide open. As soon as I let off of it, she kicked back down into passing gear. The shift linkage in the column is a little loose, but D2, D1, and R work just fine. It shifts smoothly from first to second, but as soon as I hit what should be third it slips into passing gear. At this point I am open to any advice. I thought that maybe investing in a Lokar cable may fix it, but I don't know at this point.
