mrandig
Since the '68 Charger is finally running, I decided it's time for my second post here.
I've got the usual gauge issues - no fuel, no temp, no oil pressure. In addition, my clock isn't working either. Amp gauge is fine, tach is fine, radio works, flashers are good, etc.
I traced 12v power almost all of the way to the circuit board, so I'm going to assume that the voltage limiter needs to be replaced to get the gauges working again. Either that, or each sender is bad, which I highly doubt. If that is the case, I guess we'll find out once the new RTE Limiter (IVR4) gets here.
So, I'm assuming that the new RTE Limiter will fix my problems, and that I can actually do this swap laying on my back, blind, by using only touch and feel. All the while, working around the vintage air system which is conveniently in the way.
As for the clock, what am I looking for here? I'm assuming this is an unrelated issue to the gauges. It's late and my eyes are tired, but the only power source I see, based on the service manual diagram, is tied into the light switch? I would have thought that was an instrument lamp, but that's shown as a separate circuit...
