- 7:52 AM
- Apr 13, 2012
- Granite Bay CA
The 68-70 B body 2 and 4 door cars had a 19 gallon tank.
I'm going to fill it to the brim and see what it reads. I don't believe these gauges are linear, so maybe it's off on the low side, but accurate otherwise.Think they are 18 gallon tanks.
Is your sending unit original?I'm going to fill it to the brim and see what it reads. I don't believe these gauges are linear, so maybe it's off on the low side, but accurate otherwise.
I don't think so. Best I can tell without taking the entire thing out, it's a repop. At a glance, it just looks too clean.Is your sending unit original?
If it’s a reproduction it will never read correctly on the gauge anyways. They are not made right internally.I don't think so. Best I can tell without taking the entire thing out, it's a repop. At a glance, it just looks too clean.
A good ole-fashioned gauge pulling seems to be in the near future. I think the entire thing will need to be refurbished.The PCB (printed circuit board) connections may need some solder reflow. The pins at the connector to the PCB are revit pressed and a solder flow there fixes many intermittent issues.
If you want to pull the cluster PCB and send it to me I can inspect the connections, reflow solder, and bench test each gauge. Otherwise I can walk you through it, or find a old school speedometer shop to help you.
Call Dick's speedometer in Tempe and see if they can help you.A good ole-fashioned gauge pulling seems to be in the near future. I think the entire thing will need to be refurbished.
The clock doesn't work, speedometer bounces around, fuel level is incorrect, water temp is dead, and oil pressure is intermittent.
