Does anyone know where you can buy the pins for the instrument cluster circuit board, during disassembly one of the pins pulled off the circuit board with the harness? Any feedback would be greatly appreciated.
You can solder that pin back on the board without issue. Had to do the same on my Coronet after having funky lighting issues. Just don't get any solder on the green pressboard or cross solder between two veins and you'll be just fine. Good luck
I soldered the pin back on as you suggested. Good thing I have experience with soldering. I wasn't sure it was going to hold, but actually seems stronger than before. Thanks for the feedback.
