68 Coronet Longroof
Skills??? I am learning as I go. You must be speaking about ckessel, eldub440 and quite a few others on this forum. The best I could hope for is to inspire others this is doable with a few tools and willingness to learn. Thanks for the kind words Coelcanth.
Skills? Me? Maybe. No way am I up there with David from Willowmet Garage or my old boss from the hotrod shop. Much of what I do is learn by doing. I did take a metal forming class in 13 but didn't use the skills until 10 years later. Having to relearn and it shows. Good thing most of it is covered up. If you have resources available, suck up knowledge and skills from people around you. Help out, be a shop flunky, sweep floors etc. Thats how I gained much of mine plus lots and lots of reading.
Got most of the torsion bar/front frame rail sections repalced. I also had to replace sections of the inner rocker panels where the torsion bar crossmember attaches. There were a few other patch panels required as well. The rust on this wagon is like going down a rabbit hole.
I had to modify the trans crossmember after adding the fish plates around the torsion bar crossmember sockets.
I'm soooo happy there is no metal termite damage to deal with on my 65. You are doing an awesome job.
I feel the same way with my '70 Charger. I love seeing some of the amazing work you guys do to fix rust issues that would leave me depressed and deprived of any motivation.
Here are some progress photos as the work continues. I have finished the torsion bar and front frame rail sections. I fit the AMD front floor pan sections and welded them in place. The driver side pan section was a challenge. I removed the interior pieces. I removed the existing tailgate (w/power window) to swap in a much cleaner piece (w/manual window). I will swap the regulators prior to the swap. As is the case with this wagon, the lower hinge mount area needs attention (aka rust repair). After ID'ing the spot weld locations, I use a bullet-shaped carbide bit (inexpensive set online) in a air grinder to quickly and cleanly remove the welds without damage to the sheet metal underneath. I previously used a spot weld cutter and fresh drill bits, but those become dull after a number of uses. The carbide bit is much faster, cheaper and has better results.
I should add, wear long sleeves and I recommend a face shield vs. safety glasees. The shavings fly fast and far. I always hold the air die grinder with two hands for control and a light touch.
