am3rican
In diagnosing why my tach doesn't work and my gauge cluster doesn't light up , I noticed that all the pins that connect to the round connector on the gauge cluster circuit board are loose. Some of them are also broken off in the connector. I figure I need a new dimmer switch also as there is no voltage coming out of it. My question, how do I fix the broken / lose pins on the circuit board? Do I just replace the board? Do I need a new harness,? If not how do I get the pins out?
