69 B body Accelerator cable question
Rustymopar
2:00 AM
Stevensville, Maryland
Is there a rubber boot that goes around the accelerator cable where it penetrates through the firewall? There is a reinforcing plate welded to the firewall that the upper bolts go through to the pedal assembly, but the actual hole for the cable is large and I imagine fumes would come right in.
I can't seem to find the rubber boot anywhere online. The 69 Coronet 440 (318) parts car I have has reminences of having had one.
I will check mine out on the Charger and let you know, should be similar, I put a new cable in recently.
I have some of those original rubber grommets PM me if interested
