Two for sure on the right.
Thats what I told you a while back. 3 yellows go to the right but only 2 spades. The one goes in in the barrel style jumperI assume I should have 2 on each side. The wire I am holding must go to the right then?
It kind of only works one way. So if it all lays out with the right connectors you should be ok.ok, I think I'm getting close.
Female spades 1 and 2 go to the right side, 3 & 4 to the left. I have female spade 1 attached to the split for the console wiring. The male butt should go to female butt 2 and the wire from the main harness goes to female butt 1. Is that correct?
