69 Charger Hood Mounted Turn Signal Hookup
ChargerDude
5:41 AM
N. America
OK. So, I'll just start off by saying that I'm not an electrical expert.
I've recently purchased the Hood Mounted Turn Signal assembly and wiring harness for my 1969 Charger and want to try and hook it up without having to go to my mechanic. Where do they hookup to? And yes, I found the wiring diagram online, but I don't understand the one symbol that seems to be critical for my connection.
Thanks in advance and I apologize to all those electrical engineers and mechanics who learned this years ago.
Cheers.
Just above the horn relay where the wiring meets up at...the rectangular boxes that are perpendicular with one another. (upside down T)
i believe those are your connectors at the firewall. should be female black plugs. 2 of them one to lft.one to right
any luck finding the other end ? if not someone before you could of butchered it. might need to dig a little deep and pull new wire .But.. It should be around that bulkhead connector if its there.
