69 Coronet door glass removal and actuator replacement
jeffrey kramer
New Member
5:19 PM
Iowa
I need to replace and repair some of the inside mechanical parts in the doors. The panel removal is strait forward, and I was able to re-attach the lower glass track with out removing the pan, but there are other issues that I need to address. I don't want to remove any bolts until I have an idea of the process. I could use some step by step information on how to remove the steel door pan, actuator and glass and in what order. Thank you in advance. JSK
