Tim, did you get your GTX chores done? How was hunting season?
I hope they can do it to your satisfaction. I remember when I was getting started with my GTX in 2016 and you were working on yours as well. It's going to be amazing when she drives again under her own power. Stay after it.So made the call, made a appointment for next Tues to talk to Noel Automotive, many good recommendations for them. Will talk about when and things to be done. Hopefully this will be the year I get it on the road.
You can run one wire and split that wire at a convenient place to feed each tach. Running one wire or two wires electrically is no difference - the two tachs won't see a difference.Going to try and get tach leads run tomorrow. I bought factory tach to put in dash. I'm also going to run one on the steering column. My question is can I run both off the same lead or do I need to run 2 separate wires? Thanks in advance.
