69 Roadrunner brake light switch
Moparlike
8:02 AM
Baldwinsville NY
Hey.
If I was 20 years younger and 40 lbs lighter, I probably wouldn’t be asking this question... having trouble fitting under the dash.
I’m trying to replace the brake light switch.... any tips?
It currently has the push in type. Do I push the clip/sleeve in first, then push in the switch? Or push in together?
Or is there a secret to getting the bracket out that holds the switch, then mount the switch and reinstall the bracket?
Will the switch with the two adjustment nuts work in it’s place?
Thanks!!!
There's a bolt that holds the bracket, should be towards the pass. side.
I think I used a 12mm nutdriver and removed the bracket. Having the front seat out helps.
LOL, if I remember it's sleeve first then switch; have the chiropractor on speed dial.
