Bats5
Looking for help... the previous owners of my 69 Satellite attempted to change it from a column shift to a floor shift and completely removed the shift linkage. I found a replacement from a 68 GTX, which I assume is the same. I had my daughter in the car working the column shift lever and was able to adjust the linkage to go from 1st gear to almost into park. Its about a half click from going fully into park and locking the drive shaft. If I pull down on the level attached to the steering column from under the car, it clicks into park, locking the drive shaft. No amount of adjustment will have it go fully into park. not sure what to do to correct this. any thoughts or advice is appreciated.
