69 satellite rear seat ???
Bens69PlymouthSatellite
3:51 PM
IN.
Plain and simple how the hell do I remove the rear bench seat looks like square bolts dont know if they were like that from the factory or what! Thanks
Hi Ben, The back of the rear seat is bolted, The bottom should just be clips. Push down, back and then pull. There is one on each side at the closest point to you.
The rear seat isn't bolted in. To remove the seat bottom, you have to push back then lift to release it from the "hook" it's in. The seat back will have a "loop" on the bottom of each side that a flat piece of metal sticks through, then folds over. Then pull the bottom of the back forward a bit, then slide it up. It sits on "hooks" as well
