datblackchallenger
Sat for 5 years. Cranks but won't start. Replaced ECU, voltage regulator, ballast resistor, electronic pickup in the distributer, reluctor and oil pressure sending unit, (oil light stays on any time the battery is hooked up, still on). 5 plus volts at coil. Tried 3 coils including a new MSD, (7 plus volts). it has a fire wall to engine ground.
Have 1 plus volts at the coil with the key off positive and negative side. Headlights and the console light work. Fusible link looks ok. I think maybe wiring or ignition switch issue. Where to start checking?
At least the top still works. 440 4 speed.
