7 blade fan 2863224 or 2863226?
Moms68
9:32 PM
Central CT
Looking for some information on the difference between a mopar 7 blade for 440 with a 22” 3 pass radiator. The 2863226 fans that I see for sale are much more expensive. This is not a concours restoration, just a big block upgrade.
Trying to avoid electric or clutch type fans.
Looking for a mopar 7 blade for 440 with a 22” 3 pass radiator. The 2863226 fans that I see for sale are much more expensive. This is not a concours restoration, just a big block upgrade.
Unless you just want mopar oem only Summit has a pretty good selection of all steel mechanical fans.
Is this supposed to be a WTBuy?
I run 224 curled tip fans on 4 out of 6 cars, soon to be 5 when I take the clutch fan off the '64. All cars run ON the stats with stock radiators, except the '64 with the clutch fan.
Thanks. I edited the post.
Do you already have the 2 piece metal shroud and correct spacer?
