paulie-rt
Hello all. So I've rebuilt my '70 Steering Column for my Dodge Charger with power steering. New ER-16 lower bearing ( I Highly Recommend ) and upper bearing and insulator , ignition components, inner two piece shaft length checked at 41-1/2 inches end to end. My question is this : In reinstalling the two piece inner shaft ( lightly tapping it forward from the bottom so as not to disturb the 41-1/2 " length) what is the length of the shaft section from the top upper column collar to the tip of the threads ? In other words, at what point do I know when to stop tapping the shaft inwards so the steering wheel will fit correctly and the bottom shaft will also be at correct length? Thanks all !
