Put the matching numbers engine and trans away,use other components to build what you want. If you want a manual transmission in the car, save the piece that you cut out of the floor, so it could be put back,and only tack the floor hump in,so if you want to go back to stock at a later time you can. I am going to put a four speed in my matching numbers 70 Charger R / T V code car, but I have the pieces to put it back to original condition if I choose to do so. There are things about the 70 Charger that you will really get to like,the interior is the best of the three model years of the second generation Charger.
