vance.dykes
let moparnaition74 check that dash and manual that is the way i would do it 74 is very smart on this stuff.thanks where does the yellow wire attach or plug into?
I will take pics of what I have this evening to hopefully clarify this.....thanks where does the yellow wire attach or plug into?
Looks like the horn relay....what is the pn on the back?
that isn't a flasher for turn and hazard lights it most likely the door /key in buzzer.
2983873Looks like the horn relay....what is the pn on the back?
Hard to see on my phone
i used 93596-a to get that one i posted.I will keep looking for the flashers, thanks
2983873
yes that is a flasher. isn't this fun..... lol
man you are on a roll
Did you find that piece just to the left of the fuse panel?
Thanks man I really appreciate all your helpI was correct as I said earlier, lol(just the wrong side).....It is the accessory slot....The only harness I had was for 1969...
With some research there are differences between 68/69 to the 70....As you see the accessory side is flipped in 70....
......The accessories include tach, rear window defogger, speakers(L and R) and air conditioning......
The yellow female connector with two yellow wires is for one of the door switches and the connection with the male end is for the map light(doesn't mean you have a map light)....
Download a service manual from my Mopar.....
http://www.mymopar.com/index.php?pid=109
Here are some screen shots for reference....Hope this helps!
View attachment 821610 View attachment 821611 View attachment 821612
YesDid you find that piece just to the left of the fuse panel?
I have a question if any of you can help.70 V code car...........can I ask where are the flashers up in the dash? I think I need a new one, one of my hood mounted turn signals isn't flashing properly? Someone said it wasn't grounded properly?
Look at the factory service manual for the hood turn signals. They go directly to two connectors at the bulkhead disconnect. I've had ground problems with mine and have added extra ground wires to the bulb sockets. On your front running lights, yes they should flash with the turn signals & stay on with running lights or headlights.I have a question if any of you can help.
I also have a 70 V-code Roadrunner
The pigtails of the hood mounted turn signals (on either side of the "440" plate) are not connected, and I would like to know where they connect.
Also, the 2 yellow lights in the front bumper on either side of the license plate space don't flash when I use my turn signal, but they are on solid when I turn on the parking lights and headlights.
Should they flash when I use the turn signal?
