Beekeeper
It’s a disease without a cure!
the clocks are rebuildable if the contacts inside are not burnt completely up. I have two tic toc tachs that I have rebuilt the clocks in and they are ticking and keeping time just fine.
The clock is easy to separate from the tach, three small screws and an insulating washer/spaceris it tricky to separate the clock from the tach? I didn't look too closely. Do the stock hands slide right onto the quartz kit? That sounds like the way I'm gonna go, I think.
Also, while I'm at it, to test the tach, I was going to run a jumper from the long pin to the positive battery, and from the frame to the negative battery, then run a line to the negative coil and starting her up. Sound reasonable? I haven't installed a tach before, if it doesn't show. :-D
