kc400
New Member
It has a 1978 440 big block with 727 reverse manual 3 speed on the floor. The dual carbs are over kill for this stock displacement engine. It has an 8 1/4 rear end in it (open carrier and stock gears). Goes down the road at 70 mph like my 01 f150. The following are all new , interior (all) , radiator , steering box , rims and tires , brakes and brake components with brake assist can, gas tank , eldebrock intake with 2 600 carbs , electronic ignition , all front end parts from ball joints to tie rod ends , torssion bars, fuel pump , tork converter , vinyl top , dual one piece exhaust with 2 mufflers , rear air shocks , hurst shifter and more. The paint is mainly flat blue. It would need to be repainted to have a shine.The extras are 8 3/4 complete from drum to drum open 741 carrier out of a 69 satellite , 489 carrier with sure grip posi unit , 391 gears for 489, 410 gears for 741, new mopar crome valve covers, new trans lines, orig intake with holley carb and air cleaner, another drive shaft, oil pump (used), fuel pump (used), new trans rebuild kit, new motor mounts, new trans lines, new front rim (bought for spare tire), gaskets for the engine , another distributor , orig valve body, new shocks and more odds and ends. Body is straight but has glass in quarters. $12,000 for car and $13,000 for car and parts. For more pics email me at [email protected] .
