Ok,
time to go back to school, jump ahead to 12:10 for the answer to today's question.
I suppose there is a small possibility all the Chrysler produced tech training materials could be wrong and Triple black is correct, but I don’t think so.
Fine. Let's me put it another way.
The ammeter answers the age old question can a weak 35 amp generator keep up with a weak 375 cca lead acid battery? Which is kinda important, because a 375 cca battery barely has enough to turn over an engine when fully charged, and a 35 amp alternator barely has enough juice to power headlights, the heater fan, radio, and power windows. God forbid all at once! If a generator gets overloaded, it burns up. If the battery discharged to much, it wouldn't start. So, the ammeter was very important back in the day.
Now, let's fast forward. Let's put in a 100 amp alternator with a 800 cca or 50 amp hour battery. But let's say the battery is 80% of capacity from just setting. That's still 660 CCA and 40 amp hours. Almost twice what the original design spec. That also means the outdated charging system needs to work over full capacity just to fill what was lost from just sitting! But
72RoadrunnerGTX says "there must be something really really wrong for that to happen". No man. Just a big battery at 80%. And that's enough to tax the '70s charging system to the point of self destruction.
Here's what's going to happen. There will be a huge voltage different between the alternator and the battery. The voltage regulator will see the lower voltage at the battery and direct the alternator to put out more power. It will do this until the volts on both end on equal (the battery is fully charged). However, the ammeter in our Chrysler is a "full load" design, so it will carry the full load. Since the voltage regulator will see the drop in voltage and not improving, it will tell the alternator to put out more and more and more amps to increase the volts. 20? 30? 40? 50? 60 amps? Boom. There's goes your car up in flames.
And it's exactly what I said all along. If I connected my 220 amp alternator through the ammeter to my 800 cca / 50 amp hour battery, the ammeter would be pegged deep into the 'C' and would stay there until it burned itself up.
The damn ammeter is an old design that has no place in today's world. If you upgrade the alternator or the amp or all anything to the system, bypass the ammeter. There's a reason no one car manufacture offers uses an ammeter to monitor charging levels. Modern systems puts the battery between the alternator and load to have it act like a capacitor to smooth out voltage spikes and AC whine.
72RoadrunnerGTX is seriously misleading people. He talks a good line, but present unimportant information as relevant. He glosses over the real important stuff. He doesn't use math or numbers to support his views. He want to apply old world tech in the new world. Not once has he admitted that the ammeter in Chrysler products are only useful in monitoring low amp system.
But if you guys wants to keep using them, you better keep using small alternators and small batteries.
