72 Charger 340 X heads valve cover trouble
max 7
12:22 PM
Franklinton, NC
As stated, I have a problem with my valve covers. I have mopar performance valve covers. The oil fill cap is on the left for both valve covers. My problem is where I have to have my breather cap for my setup. I need my breather cap on the drivers side in the front(left for the valve cover.) So my breather cap would be going where a fill cap is supposed to be. Well I ran it like that for awhile and I had to pull everything because I blew my intake gaskets. When I pulled my breather cap, I saw there was oil seeping all around my grommet because it doesn't seal correctly that way. I also have a pcv valve on my other valve cover on the passengers side in the front(right on the valve cover.) Anybody know of a way I can make it work? I don't want to put it near my linkages. If I have to does anyone know where I can find aluminum valve covers where the oil fill is on the right?
