FOR SALE 72 Charger SE
harleydodge1
4:21 PM
alabama
$10,000
318-auto-air-ps-pb
Car is located in north Alabama near Huntsville.
IT will come with the factory steel wheels and factory hubcaps NOT THE SALTFLATS.
Lots of options
Car had been sitting in a garage for over 20 years when we got it.
Changed the oil and added some new gas and she fired right up.
Runs and drives pretty good now but will need some tinkering to be road worthy.
Runs but floods out pretty easily.
No rust other than 1 small place on each A pillar
Spend thousands in rust repair or buy rust free car and save time and money
NEW PARTS INSTALLED
Electronic ignition
Plug wires
Trans fluid, filter and shifter shaft seal
Intake gaskets
Valve cover gaskets
Coolant
Brake master cylinders
Brake calipers
Brake hoses
Brake pads
Tie rod ends
Tie rod links
Idler arm
THE BAD
Both quarters have accident repairs
Passenger side will probably need replaced. Bondo cracking
Drivers could be saved. Bondo cracking
Most interior plastic parts are brittle
1 rust hole on each A pillar from the vinyl top
Some surface rust on top but no soft places
THE GOOD
Other than the quarters it is VERY straight and NO other rust.
No rust underneath
Front and rear valances are perfect
All glass is good
Other than the hard interior parts all is in great shape
Seats are great
Headliner is great
All trim is there and good
Carpet is good but faded
All lights work
All gauges other than the speedometer and clock work
Flip up headlights work
Trunk pans are perfect
Car will come with a bill of sale and a current tag receipt
ALABAMA DOES NOT ISSUE A TITLE FOR CARS OF THIS AGE
If interested PM me your number and I will call you back
Will not answer questions here. I will call you back and answer all questions over the phone
