FOR SALE 1972 Charger SE factory sunroof
12:28 PM
CO
$15,000
Fort Morgan, CO 80701
factory big block car(400 don’t have)Has 383 and 727 torqueflite. Hi-po manifolds, Mopar performance electronic ignition. Posi 8 3/4” rear end. Rear sway bar. Factory sunroof new seals, rear defrost, power windows. Factory Floor ratchet shifter. I have 3 hoods for it. Factory flat hood, power bulge hood and the one currently on it with the scoop.
Everything works. New brakes. Have new parts for sunroof not installed. Hide away headlights. Drives great.
edelbrock 750 carb. hooked up with the original linkage for the transmission kick down. new water pump. new power steering pump
Rust behind both rear tires, will need patched. Otherwise body is great.
I could be interested but I hace some questions if you are willing. Front looks 73 or 74. Do you have a 72 hood? Picture of the vin? Is there anything in the engine compartment that is 72? Was it wrecked or salvage? Missing trim for a se hardtop? Was it bench before, wondering about white se brougham interior but black buckets.
The front bumper is from a 73. I have the original 72 bumper with the emblem in the center but it was more scuffed than the 73 I put on. The same story with the front valance. When I got it the passenger fender had been replaced. Yes I have the original 72 flat hood.
As far as I know transmission is original, but have not confirmed that. I have all the trim. It was a white vinyl top. It was a bench I believe, however when I got it it didn’t have the original bench in it. I put the bucket seats in. And the floor shifter as well as changed the column to a floor shift column.
Happy to answer any other questions
Do you have pictures of the engine, and better pictures of the interior, including front seats (are front seats factory B body?) Does sunroof work properly? What extra parts are with the sunroof? How is the trunk metal?
Also .. power windows all work good??
Front seats are just some aftermarket racing seats I bought. I do like the way they feel. But far from factory. Sunroof has all new cables and seals. I haven’t installed any of it. Waiting to paint first. I will try to get a photo of the new parts tomorrow.
All the electric windows work. Drivers side is kind of slow. Trunk is great. No Rust. Deck lid has that 1 ding in it
New sunroof parts. The old brackets are in there along with new ones on the cables
