72 Plymouth Satellite 318 2bbl to 4bbl
drader
11:24 PM
I am restoring a 72' Plymouth Satellite Sebring converting from original 2bbl to a 4bbl Edelbrock intake/carb. I have read previous posts and have tryed several options to get the throttle cable and kickdown to align properly. Unfortunately, no luck.
I purchased a 340 4bbl bracket from Classic Industries understanding that it would provide the proper alignment setup for my conversion. Unfortunately, the bracket had a different bolt pattern to the intake manifold. I then modified the original bracket by bending the throttle cable attach up moving it outboard for proper alignment. But, the kickdown looks to interfere with the modified attach point for operation.
Are there any other options I have over looked to get a good alignment of the throttle cable and kickdown rod in proper alignment and operation? Any time and considerations are appreciated.
Some times you have to "tweek" the bracket to make everything align.
This photo is using the 2 bbl kickdown with a aftermarket throttle cable. Maybe it will help.
I had to bend the bracket for alignment.
Darter6 thank you for your help.
Do you remember the aftermarket cable length and manufacturer?
Sorry I was at the MATS car show in Vegas. It was Spectre. Got it at Auto Zone $29.
View attachment 1815438View attachment 1815439View attachment 1815440View attachment 1815441
Looking good. How is the car coming along...been driving it much?
Drader - the bracket you purchased from Classic Industries is to be positioned further back on the intake.
The bolt pattern is for the last two holes on the intake.
The area between the bolt holes on the bracket does not have the clearance to sit above the #5 & 7 intake ports like your stock one does.
