74bird
Bought a 72 runner with 11 Drums and have hit a snag. Car had weld wheels that had 3 inch lugs pressed in and wanted to replace with factory rallyes using standard factory lugs. Removed the lugs and bought factory lugs knurl .673 to replace. So here is the problem, the 3 inch lugs which were pressed in opened the lug stud hole so when putting in the factory replacement .673 knurl lugs they slide into the front hub/rear axle and turn. Basically no need to press them in. So I am looking for some ideas on how to get through this mess without replacing the rear axles and going to disks on the front.
Thanks!
Thanks!
