Rockland71GTX
I tried to find a Chrysler specific diagram, but this is the best I could do for now. It will give you an idea of the inner working of the switch. Check for continuity like from the brake light feed to the left and right brake light.
The side markers coming on with the brakes sounds like a ground issue on the tail light housings causing backfeed to the side markers.
Check that the hazard switch is in the right position and maybe cycle it a few times to make sure there is good contact.
The contact plate on the steering wheel may not be making good contact with the switch, recheck that and try the horn at different positions of the wheel.
Good luck!
Good luck!
