Lucky for me it's not low hanging. It's higher up than the headers, which aren't low hanging either.If you have a good fluid cooler [ I have used two ], I see no reason for a low hanging deep oil pan.....
Before you install it I'd remove the allen key drain plug and put a bit of thread sealer on it. The other hole is sealed by a bolt with an O ring and doesn't leak.I have just ordered mine from the local dealer.....should be here by Saturday from Australia. The local mob sells mostly Chebby stuff.
Indent order.
